Old 09-11-2012, 04:26 PM   #6 (permalink)
arekkocowicz
Corsi - '04 Opel Corsa
90 day: 45.32 mpg (US)
This mentioned signal 0...5V is an analog one and it is proportional to frequency, ok, but if we are talking about injectors you have to synchronize generated freqency to the position of pistons, right? If you write more about input and output signals I might help you with designing such a circuit. What is a source of that 0...5V signal, load for output signal will be a fuel injector, right? Can you write what type of fuel injector? Are you going to connect two IC engines in series and controll them with one ECU?
