Originally Posted by Weather Spotter
many GM cars have a fuse in the box for "ignition" or "injectors". see if you can find that one and then you can add a switch inline to that fuse.
That's exactly what I did for my kill switch. I took a spare fuse, carved away excess plastic, cut the fuse wire, soldered leads onto the terminals, and potted the solder connections with Bondo. If I need to remove it, I need only pull the connector, and replace with a stock fuse.
