Yup i have a ScanGauge
On my first run with the lower grille blocked plus tape on the top the temp climbed to 210F when the normal is 190F so i took off the top tape.
...And after seeing the fairly reasonable gains i started to construct my Semi-Permanent "remove on the fly" lower grille block + fog light covers.
