Old 09-12-2012, 03:35 AM   #2 (permalink)
oil pan 4
I run an electric water pump and turning the pump off during warm up is never something I would try.
The engine block and cylinder heads need to be warmed up as evenly as possible, you want to keep that delta temperature between the heads and block as low as possible or you will be poping head gaskets.
One thing I do is run the pump at lower speed during the winter months for the first few minutes after start up.
