Old 09-12-2012, 04:57 AM   #21 (permalink)
oil pan 4
Originally Posted by Diesel_Dave View Post
Diesels typically aren't as optimized for reduced pumping losses (high VE) as you might think. In typical spark-ignited naturally aspirated gassers, high VE is pretty much the only way to get more torque at any given speed. So if you want to get more torque you pretty much have to increase the VE. On a diesel however, you can just add a little more fuel and/or a little more boost and you'll get the torque. Sure the FE will be sub-optimal, but it's just so much easier than redesigning heads and intakes.
It just goes to show you how well the efficiency concept of a combined cycle intercooled turbodiesel engine works.
They started off real efficient and cranked out amazing power levels with out much added complexity or engineering.
Fuel economy didn't matter much as diesels could beat their gas fuelled counterparts with ease in head to head tests and on top of that diesel fuel was quite a bit cheaper than gas until about 10 years ago.
But times are changing and with diesel fuel prices projected to soon rocket past $4/gal in the U.S., adaptations need to be made.
