Old 09-13-2012, 02:28 AM   #25 (permalink)
a8ksh4
B.O. Zen
Pickup - '99 Toyota Tacoma 2wd, Regular Cab, Short Bed
90 day: 34.62 mpg (US)
Well, I had a couple more tries at getting the bend in the foam to work, but kept breaking it... might be cause I couldn't really cut clean grooves w/ the dremel. :/ Anyway, the new strategy will be laying the panels lengthwise, letting them overlap at the corners, and just sanding in the curve like Chaz suggests.
No new pics today, but I put the rest of the bracing in between each x-section for the shell and should be ready to cut & screw on the top and side panels using the alternate method in the next couple of days.
