Originally Posted by niky
The premise given is that you install it between the brake and the wheel, but it looks like it actually replaces the brake. The half of the motor on the strut side is stationary, just like the brake calipers or shoes are stationary, while the half on the wheel side moves with the hub. Simplicity itself.
I don't consider replacing the brake simplicity, because that involves making a rather specific hub motor for every car. Besides, reduced braking function on the rear wheels is quite a large compromise, that I think sensible people would consider unacceptable. Weight transfer may leave the rear axle with perhaps under 40% of the weight for taller vehicles, but the hub motor is never going to be able to apply enough torque to lock the wheels even in that case. Losing even 20% of braking capacity is huge. And on RWD cars (I know I know, most people here think RWD is stupid or something), you absolutely cannot replace the brake because the front does more braking.
Many cars aren't coming with drum brakes anyhow, because they suck. The secondary drum brakes used for the handbrake are not going to suffice either. Heck, the Honda Accord (current one at least) has rear disk brakes.
Even if braking performance weren't an issue, is embedding the motor armature into a new "brake" hub really easier than just bolting a motor to the spindle and using gears?
