chysler uses an ASD (automatic shutdown relay) that, under normal conditions allows the engine to run, if it loses the crank sensor (engine won't know when to fire) it kills the injectors and coils. i assume most all cars will have something similar.
also, to maintain your warranty, it may be helpful to buy an extra wiring harness of whatever you might need to cut.
