I got the control tray mounted and almost done with the low voltage wiring.
This evening I removed the power steering pump and looped the hoses together, keeping the fluid reservoir.
I'm getting closer to test driving! Tomorrow I am finishing up the low voltage wiring, then hooking up the high voltage motor wiring, installing the speed sensor and testing the 12 volt system. Once that work, I work on installing the battery rack and batteries!
There is a good chance of a test drive Sunday afternoon!
