Looks like the stock cam has 192 degrees duration, 330 lift and the econo grind has 184 degrees, 305 lift:
TeamSwift • View topic - Cam profiles for all models [3 Tech]
Saturn s series dual cam, 4 valve engine has 200 degrees intake and 180 degrees exhaust duration, intake opens 7.5 degrees btdc. Max hp at 5600 rpm.
