Old 09-15-2012, 11:41 AM   #4 (permalink)
ron
double eagles - '99 Dodge ram slt
90 day: 19.48 mpg (US)
is fuel pump in the tank? ever run the tank as low as possible to check max mileage? then with 165000 mi on the car and a problem (stalling) that kicks out a code you cant figure out , I suggest a new pump before it leaves you stranded . by the way dont spend a bunch of money on all the easy to change 20-50$ stuff, cut to the chase and change the pump(yourself if possible)
