Originally Posted by cyclist916
What is Lambda?
Oxygen equivalence ratio (I think that's the correct chemistry term for it).
<1 is rich, >1 is lean.
By the way, today I told a passenger to watch my phone for me and apparently it wasn't giving me measured lambda readings! I also looked at the commanded AFR and it just said 0.00:1
I hope it's not because my adapter was 11 dollars and doesn't read as much stuff as it should...
Also apparently my %load maxes out at 75%, so I wonder if my air filter is really clogged or something.
