Old 09-16-2012, 01:21 AM   #4 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by California98Civic View Post
When I look at the way the tufts behave at the trailing edge of the kam, I wonder if the flow is worse than stock. I ask because of this image:
Assuming that Brucepick's Kammback has the ideal 12-14° degree slope, then the stock Civic's effective rear slope is greater. Since Cal98's tuft testing showed that the slope isn't steep enough to get separation, then the air flow must be producing lift.
So the Kammback reduces lift and Cx, but at the cost of larger wake area. Which is better in this case must be A-B-A-B tested. And that would be a great chance to also test a longer Kammback
