OK ,so here is what my son and I went thru with his problem . we replaced the filter (pain in the butt location )fire wall ,plug wires and plugs. again (I dont like the small electrode tip ) Made a pressure test adaptor for the fuel line , throttle position sensor , got a used distributor from the local wrecking yard , tested every thing again and again. always stalled and would start up again but with increasing frequency in lenght to refire . when I had exhausted every other option and spent hours and lots of cash on things the computer codes pointed to, I finally came to the pump. auto zone unit around a 100bucks ,reused our pickup and sending unit. and it runs great . thats why I say just do it and eliminate it as a problem and dont run below 1/4 tank the fuel cools the pump.
