Old 09-17-2012, 06:19 AM   #46 (permalink)
some_other_dave
Originally Posted by suspectnumber961 View Post
IF I were to do this mod...I would block AFTER the MAF so that potentially I could still have a functioning SGII.
The SG will function anyway. It is merely reading signals off of the electronic bus in the car. If you monkey with the MAF, the readings may or may not be correct, but you will still get readings.
-soD
