Old 09-18-2012, 01:30 AM   #16 (permalink)
vacationtime247
vacationtime247's Avatar
The Toylet - '87 Toyota Supra 350 Chevy V8 / 700R4
In-Durrrr-Oh - '09 TMEC Enduro TMEC 200cc Enduro
90 day: 60.9 mpg (US)
Tem-poo - '86 Ford Tempo GL 4 Door 2.0 Liter Diesel 5 Speed
90 day: 47.52 mpg (US)
Ass Tick - '01 Pontiac Pontiac Aztek GT 5 Door
Green Baby Poop Stain - '01 Pontiac Aztek Aztek Base Model
Black Track - '01 Pontiac Aztek GT
Measure for clearance first. The 6.2 & 6.5 GM Diesel are taller and wider. You'll have to relocate the motor mounts up. The oil pan might need some modification too. Had to notch my oil pan in the back to clear the crossmember in my '91 Caprice Wagon 6.2 conversion. With my mounts, I'll bolt them to the engine and set it in loose. Have the motor mounts welded on to the crossmember after the trans is bolted in. It can be done, and if you can find a cheap 6.2 and an overdrive 700R4 or 200R4 it'd be sweet.
VT247
