old thread, i know, but i ran across this and decided to add it here for people to see.
this is from another forum i used to visit often, nearly dead now.
Originally Posted by shadowvox6 View Post
Group,
Friday we had our Dyno Session with Axcelerated Motorsports...
I was impressed with what the Special did on the dyno.
The only significant changes were:
-Going back to a K&N FIPK from the JoeKD
-Intake Spacer
We picked up a phenomonal amounf ot torque...32 ft-lbs.
Went from a max of 184.26 ft/lbs in 2008...
...to 215.03 ft-lbs in 2009. (This is an all time record number here FWIW)
Horsepower was virtually unchanged...staying at 186 whp.
The torque curve is also flatter than without it.
The power band is also shifted downward at bit, much as we have seen in the Intake Spacer 1.0
This validates the Intake Spacer as a definete worth while mod to do.
I will post the dyno chart later.
full thread can be found here
2009 Dyno Pulls from Carlisle - DodgeIntrepid.Net Forums - Dodge Intrepid, Concorde, 300m and Eagle Vision chat
