Old 09-18-2012, 10:31 AM   #67 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
David,
You can just wire them all in parallel and connect a CV power supply dialed in to what voltage you want and let it go for probably a day. Once the current tapers, to a specific value, you should be all set.
This is how I eventually plan to do my cells.....eventually....
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
The Following User Says Thank You to adamj12b For This Useful Post:
Cobb (09-19-2012)
