Thanks for the report Francis. The installation looks great. The only thing I would like to suggest is that you carefully seal the blue "Scotch Lock" connector with silicone. Or better yet, solder the connections and cover them with heat shrink tubing to keep the moisture and road salt from causing corrosion and bad connections later.
Mike
2007 ZENN and 2019 Chevy Bolt EV 145,000 oil free miles to date.
