Old 09-20-2012, 10:52 AM   #6 (permalink)
RiderofBikes
Pantry Boy Supreme (pbs) - '04 Volvo S80 T6 Premier
"if you build it, they will come" Epic Wood!! :chuckles:
But seriously, if i had a beater i'd be doing this as well. Anyone ever see the PT cruiser truck?
Your particular car doesn't look too Rain freindly?! any plans to make it rain friendly?
How is handling, any oversteer? 500lbs is ALOT of weight to reduce from the rear
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
The Following User Says Thank You to RiderofBikes For This Useful Post:
darrylrobida (09-20-2012)
