Old 09-20-2012, 03:29 PM   #6 (permalink)
arekkocowicz
Corsi - '04 Opel Corsa
90 day: 45.32 mpg (US)
Yes, I've installed it in two cars. I supply my circuits from lambda sensor heater and I noticed that in Fiat heater is continuously on but in Opel heater is supplied with low frequency PWM. I will try to film it and upload somehow. There is also obvious problem that cold lambda sensor doesn't work so first couple of second after engine start it shows constant voltage which in Opel is interpreted as Rich (that's logic, right?) but if Fiat it shows voltage corresponding to lean mixture
