So if you stay below 20tps and above 2400 rpm on the freeway for 2 miles it will turn on by itself? I'd like to see if mmo works for turbovr4 an if it does I'll give it a try. Was anyone able to find the led light thing? I have a narrow band a/f gauge. Would that be able to give me an idea if I am in LB? Also I was reading on here and I saw that the HX can do lean burn regardless of the second o2 sensor and the stupid restrictive cat? Because a long time ago I had headers and no o2 plugged in and I got pretty decent mileage before I was a hyper miler. I'd like to try something like that again. But I'd have the o2 plugged in this time. Maybe out spaced a little outside of the direct flow of exhaust.
