There is a tunable 2-3D mappable plasma ignition in the pipeworks - when that is available I will be in like a rat up a drain pipe. That should enable the leanest possible burn an engine can tolerate. I'm also keen to check rumours that plasma will explode water mist as any power there will enable leaner fuel mix and still maintain enough hp for cruising. In the meantime I'll leave that idea as crack pot science ;-)
