Originally Posted by 02Eclipse
First time poster but long time lurker, quick question... Does the chart you supply in the first post apply to an flat plane in the ground plane? Like in the 10 inches or so from the ground that most bellypans are? One other question, since most cars employ a rake (front of vehicle is lower to the ground than the rear) is this closer to an airfoil shape that you refer to or is it closer to a flat plane?
The OP seems to have disappeared.
I'd like him to define "airfoil shaped" as regards a belly pan. Exactly what does that mean? Got pics?
I'd also like him to define "optimal:" If a belly pan is "suboptimal," then what's optimal? Exactly how does an irregular or rough shape become less draggy than a smooth one? Where else in aerodynamics is this true? After all, the fact that a surface is upside down should not effect how slippery it is or isn't.
