first off welcome. As i understand it less dense air such as humid, hot, air contains less oxygen and requires less gas to burn and make exhaust that is acceptable to your ecu. more simply put the ecu is looking for a certain mix of exhaust gasses and will use less gas when there is less oxygen in the incoming air. this being the reason for people building warm air intakes.- not claiming to be right, just sharing what i understand.
![Smile](/forum/images/smilies/smile.gif)
