Also not sure if moon caps would snap onto the rim of the alloy wheels as well as steel rims (I have alloy).
You have to remove a Moon caps to check the tire pressure, I would think the snap-on would loosen eventually if they fit at all. Maybe you could find a way to trade down to steel rims at little or no cost.
Once you have steel rims you could use Dzus fasteners:
Installing Moon Discs
