Old 09-24-2012, 06:50 PM   #12 (permalink)
GMPG
I got the air dam, hood cowl and grille blocks done and then took the car out for some tests while it was still light. Note that I did NOT adjust tire pressure before this, I'm still at the 34psi I normally run. I'll be changing that to 38-40psi in the morning before I leave.
I'm going to pack the car now and then if I have time I'll knock out some simpler rear wheel spats... duct tape is a wonderful thing.
Coast down:
42.56 seconds from 60mph to 35mph.
45.24 seconds from 60mph to 35mph with mods
-mods, upper and lower grill block, air dam, hood cowl.
2.68 seconds longer to coast down
Hill Coast, Stock:
Entry marker 55mph
Mid point 62mph
Exit point 55.5mph
Hill coast with mods as above in this post.
Entry marker 55mph
Mid point 63mph
Exit point 57.5
Up 1mph at the mid point and 2mph at the exit. I also was rolling several mph faster when I hit the 35mph sign coming into my town that I normally hit right at 35mph while coasting.
The Following User Says Thank You to GMPG For This Useful Post:
MetroMPG (09-25-2012)
