Old 09-25-2012, 12:15 AM   #76 (permalink)
SeniorSell
Dave Upton
Thank you, Thank you! I was making this way to hard. What you are explaining makes perfect sense. Firewall mounted starter relay controlled by the 12 car battery and a fused maintained switch. Attach #10 Solid to Field terminal (1) and the other end to the starter relay side (a). Attach another #10 solid to terminal (b) on the starter relay and attach the other end to Field terminal (2).
Is the length of wire important? 6", 12", 20" each?
Thanks again,
Dave
