Old 09-25-2012, 02:34 PM   #35 (permalink)
undata
Mr. White Guy - '97 VW Passat TDI
Blue Thunder - '04 Chevy Aveo 4dr-sedan
cinquecento rossa - '12 Fiat 500 Pop
Higher pressure makes the tire more likely to ride over something than sink onto it. Also, a good firm tire is better under wet conditions, because it can better channel water than hydroplane on the surface like a sloppy tire would. But I would never ever go over the max pressure listed on the sidewall. I just imagine hearing a tire design engineer's comments on the subject.
