Originally Posted by Daox
Well, you have a automatic, so you might be loosing a bunch of power to the torque converter. Also, are you sure you're in closed loop at 95% load? If not, that will hurt mileage.
yea closed loop even in 99% load. only open loop if rpm over 4k and wot. 99% load doesnt equal 100% throttle though. the lod is kind of sensitive and maybe even inaccurate.
