Old 09-25-2012, 06:08 PM   #154 (permalink)
renault_megane_dci
la_voiture_de_courses - '03 Renault Megane Estate
OldContinents
90 day: 44.34 mpg (US)
xiao lan - '01 Audi A2
90 day: 38.88 mpg (US)
Brit iron - '92 Mini Mini
90 day: 45.5 mpg (US)
Prius - '09 Toyota PRIUS Lounge
90 day: 47.37 mpg (US)
Beemer - '06 BMW F800 ST
90 day: 53.06 mpg (US)
Originally Posted by hyper-miler View Post
Would you be able to attach the "lower pieces" to the top pieces via a spring/slide mechanism, so when the wheels go up so does the bottom half of the tail rises. This would allow the tail to be closer to the ground without touching on large potholes/bumps. I am making the assumption that the bottom pieces are separate from the top.
Usually the wheel travel are in the 150 mm range so you might miss those to the ground.
What is more leaning angle is better not altered, so this clearance might prove useful.
On a sliding panel point of view, I am definitely up for a front wheel bottom panel which will close the front wheel steering louvres gap at all times (if that make sense)
Also what are do you guys think putting a small high torque motor on the back disc brake to enable lower gears on the counter shaft and rear sprocket?
Streamlining already helps in this departement : a bike lower gears are ridiculously low as is because they need to be able to carry a heavy weight and taller front / smaller rear sprocket usually hit top speed rather than take offs.
