Old 09-25-2012, 10:56 PM   #37 (permalink)
niky
Originally Posted by undata View Post
Higher pressure makes the tire more likely to ride over something than sink onto it. Also, a good firm tire is better under wet conditions, because it can better channel water than hydroplane on the surface like a sloppy tire would. But I would never ever go over the max pressure listed on the sidewall. I just imagine hearing a tire design engineer's comments on the subject.
While higher pressure is good for preventing hydroplaning, it's because the opposite is true. A firmer tire sinks or cuts into the water better, which is why you want to pressure up to prevent hydroplaning.
LOWER pressures make tires more likely to ride over water puddles, causing hydroplaning. But this is also the reason we use lower pressures off road, to keep the tires from sinking more into the mud.
