I can't make any comments on a block heater as I have never/ used one. But I think it would definitely be worth some engine bay insulation, Belly pan, grill block, sealing gaps, etc. It will help the motor to warm up faster, and hold heat a lot longer after shutdown. If the Element doesn't have any insulation directly on the bottom of the hood, I would suggest finding some off of another car.
