Old 09-26-2012, 10:44 PM   #5862 (permalink)
Crossdan
Paul,
No worries. I'm already ahead of the game by having a controller that I can replace components on (assuming they're bad).
Just to make sure I don't have bigger problems, after the pre-charge timer expires I should record 12 volts between the +12v and the contactor, correct?
Jerald,
At no time, either before or after the pre-charge timer expires do I get 12 volts across the contactor (middle) terminal and ground. I'm hoping Paul doesn't tell me I have bigger problems.
I have my car on jacks waiting for the controller to spin the wheels. I'll try to install this weekend with a 24 v pack to test the motor control portion of the OpenRevolt. If that doesnt work then i definitely have bigger issues.
Dan
