Old 09-26-2012, 11:09 PM   #5863 (permalink)
jedsmd
PLUGnGO
jedsmd's Avatar
Originally Posted by Crossdan View Post
Paul,
No worries. I'm already ahead of the game by having a controller that I can replace components on (assuming they're bad).
Just to make sure I don't have bigger problems, after the pre-charge timer expires I should record 12 volts between the +12v and the contactor, correct?
Jerald,
At no time, either before or after the pre-charge timer expires do I get 12 volts across the contactor (middle) terminal and ground. I'm hoping Paul doesn't tell me I have bigger problems.
I have my car on jacks waiting for the controller to spin the wheels. I'll try to install this weekend with a 24 v pack to test the motor control portion of the OpenRevolt. If that doesnt work then i definitely have bigger issues.
Dan
CrossDan
I think there is a software switch that needs to be set before the contactor will work. Other people have written about having problems with it. Hopefully someone more familiar will chime in....
Jerald
