Old 09-27-2012, 10:50 AM   #5 (permalink)
mechman600
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
DI also requires much more precision in the injection system. IDI engines can get away with cheap injection pumps and injectors. Converting to DI would most likely require swapping to a much more expensive pump and injectors to get the pressure/atomization required. You could probably find something in the junk yard.
