Old 09-27-2012, 03:24 PM   #8 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
I live about 60 miles from Anchorage. Most parking lots do not have places to plug in. Most people around here just get by with a single block heater. They leave it plugged in all night though.
I suggest an oil pan heater, coolant heater. A battery blanket is not really necessarily as this area of Alaska does not see the bitter cold. connect those to a timer that turns on about 1.5 hours before your commute, the purpose of the coolant heater is to get you warm air instantly, use just enough time to get that.
Good winter tires is a must. studded does not seem much better than a good snow flake rated tire. Michelin x ice, or hankook Ipike rock. Both have a 45-55 psi max rating, I noted no decrease in mileage with the Ipike on my civic. I did have to drop the pressure slightly as I would get wicked wheelhop if the tires spun at 55psi but if I dropped them to 48 they were fine.
Even if you cannot plug in during the day it is worth it for even just the morning commute.
Insulation helps for about 5-6 hours but after that with any kind of air movement it is ineffective. (This is based on my experience with aircraft which are more tightly cowled than cars).
If you have any other questions about Anchorage or the Valley PM me.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
