Old 09-27-2012, 03:35 PM   #40 (permalink)
jared1970
BarelyAwake, how is your trike coming along? I just found this thread and think your project is interesting. Have you considered using the engine as a generator for the electric hub rather than connecting it mechanically to the wheel? This could eliminate the problem of premature wear on the geared hub. Just use the engine as a range extender like the Chevy Volt does. I'm not sure how you could do it, but if you've managed to build this thing up to this point you're probably clever enough to make it happen.
