Sorry, maybe i confused things. I HAVE programmed the pre-charge. After 8 seconds it goes from 0 to 12 volts.
The question is:
Should the 12 volts come from contactor (middle) terminal and ground.
Or from contactor (middle) terminal and +12v supply. (this where I'm getting the 12v)
I just don't get enough amps to pull down the relay.
Dan
