Old 09-28-2012, 07:22 PM   #19 (permalink)
ev99saturn
ev99saturn's Avatar
Snake Oil - '10 Factory Five Racing Mk4
90 day: 77 mpg (US)
Ya, I will have to consider getting some narrower tires if they are that much of a difference. The front tires are only 245 wide, maybe the same set on the rear, or would you go narrower all around?
No top for it now, although FFR offers both a hard top and a soft top add-on.
Originally Posted by Ryland View Post
315mm wide tires on the rear are really wide tires and I see they seem to only make that size in sticky rubber compound for being on the track, so that is also hurting your range by at least 10% if not more, so why not a set of tires/wheels for car shows and other events and a set for daily driving when you want that extra range? I would think if you went with something that had a vintage look to match the style of car wouldn't look out of place.
I know you said you didn't want to go with narrower tires but I think small compromises can be made.
Do you have a hard top or is there even an option for a hard top? or is it just a fair weather open top car?
