Old 09-29-2012, 09:52 AM   #6 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
So far...no cleaning. Got it. Still gonna press forward with my project.
Cleaning process should work on O2 sensors as well...but since they are cheap enough (less than $100 each), why bother.
Why wait until the catalytic converter throws codes if yer gitting instant higher MPG and HP? When you git a brand new (or new to you) car, just drop it the converter down (bolts aren't even rusty yet on a new car) and bust that sucker out! Better MPG and HP over the stock numbers!
High heat doesn't keep the converter clean...really. Build up will eventually clog the converter as I believe it doesn't happen in a linear fashion. Same thing goes fer air and oil filters.
I'm not using just water...I'm using a heated weak ~0.1 M citric acid and oxalic acid solution that I'm gonna cycle through the catalytic converter. I haven't see what the grid of a converter looks after 380,000 miles yet... I did find this on the internet...not sure on the mileage or what brand/type of gasoline that was used on it.
Dark Aero-The world's first aerodynamic single wheel boat tail!
