Well, I work with CAN bus a bit at work, but we always use a CAN-to-USB adapter. Those are a couple hundred dollars each. The hobbyist way is to pick up a $30 Arduino microcontroller and use it. It's almost a plug-n-play project anymore. You "could" get some kind of speed reading, run it into the arduino, and have it control your pump speed. I doubt that it would be that easy, but it's something to try.
You'll need to be able to do some programming, or have a buddy that can.
Reason: added programming requirement.
