arcosine- Are you saying there is a transmission available that will bolt right up to my engine that will allow for lower cruising RPM's?
Belly pan is almost done!
I still have a few holes to cut out of the front section of the belly pan for the exhaust, oil pan, and oil filter.
Does anybody with belly pan experience have any tips or tricks?
I plan on covering the exhaust tunnel with some sheet metal because I didn't think the coroplast would do well covering that area.
