Old 09-30-2012, 12:13 AM   #184 (permalink)
Cardinal Grammeter
Cardinal Grammeter's Avatar
TLC - '91 Geo Metro
90 day: 31.07 mpg (US)
What analysis?
Yes, most do affect mileage, but that is the particular mileage for a particular condition. Once you have that locked in, then mpg is a function of throttle position.
Whatever the Scion did, the mpg displayed and fuel consumption at fill up were consistent.
I'm trying to visualize a "carburetor" as a fixed orifice (fixed throttle position) where fuel is entrained as a function of Velocity (really V**2 but carbs are tricked out with secondary air bleeds and emulsion tubes to make them linear-ish).
Orifice discharge coefficients are not linear. At low flow they are failrly linearly however. So if you double the speed of the engine, you double the flow and V and double the fuel (assuming incompressible flow like a liquid). But you've also doubled the distance traveled too - per unit time(!)
Double fuel, double distance = same mpg.
So if the discharge coefficient is fairly linear, I guess it makes sense.
______________________
If someone sees a different explanation, please expound upon it.
Thanks
Tom
