My commute was 18 miles or so. Mornings I used a block heater 65+ mpg on the drive to work was easily attainable. Mornings I did not use the block heater 55 was a struggle. The mile out of my neighborhood would see at least a 10mpg drop if I did not use the heater. I did this several times. I realize the plural of anecdote is not data but it certainly convinced me. If you run the block heater on a timer the hit to the electric bill is not much (if you run it all night...well stupid hurts)
Additionally I would have hot air coming from the vents before the mile in the neighborhood was up (20mpg speed limit) With out the block heater I would have warm air about a mile or so after I hit the 55mph road. So on the comfort (and safety as I could keep the window defrosted) the block heater is totally worth it. The fuel savings is a nice bonus)
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
