One consideration is that 96+ are OBD2, so you can use a ScanGauge or UltraGauge. Those can really help you refine your hypermiling technique if you use them well.
Earlier cars (well, the fuel-injected ones) can be set up to use the MPGuino, but that requires some splicing into the car's wiring which can be a little tricky. And you have to build the MPGuino yourself, or buy it from someone else who built it themselves.
-soD
