Old 09-30-2012, 10:15 PM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
More important then pads is going to be that the seals that act as a return spring on the piston is good and that the piston is smooth, that the pins that let it float side to side move freely and that there isn't a bunch of crud in your brake lines that will bind up and wear out the system.
The Following 2 Users Say Thank You to Ryland For This Useful Post:
101Volts (06-10-2017), orbywan (10-01-2012)
