Old 10-01-2012, 01:31 AM   #2 (permalink)
bestclimb
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
you should look at the signal from the VSS with a multimeter, or an ociloscope if you can. it should be 0 up to 5 or so then back to 0, like a switch getting turned on and off while rolling slowly. where is the VSS at on the ranger? is it a mechanical linkage to the cluster then a VSS signal generated there?
You may be able to bolt in (then wire) a later model VSS to the transfer case or transmission.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
