Originally Posted by dcb
re: kill switches, I'm a convert to the ignition type kill switch. I've done the fuel system cutoff and inevitably they stumble on after hitting the switch (even with mpfi). It is better to interrupt the ignition signal from the camshaft/crankshaft sensor.
So how long does it take to burn the fuel left on the intake valves? Would keeping the throttle open for an instant longer clean it up faster?
