Old 10-01-2012, 06:57 PM   #115 (permalink)
Cobb
Are you using the OEM ac system or something cobbled together or aftermarket? Does it take the full 2.5 hp or how much? Does the load of the ac vary or is it constant when the compressor is on.
Sounds like a winner. I drove the leaf 40 miles, plugged it in for an hour and I was ready to call a tow truck to move it any further.
Originally Posted by TheSGC View Post
I have a 2.5 HP motor to run the Air Conditioning, which is hooked up via a belt and pulley system.
I also can't hook up anything to the rear shaft of my motor except the speed sensor, the frame of the car is in the way.
